So you just installed your fancy new exhaust but now have a pesky "Check Engine" light showing on your dash due to the removal or disconnection of the exhaust servo. Woodcraft's Servo Buddy available from Riders Discount solves this issue with a simple factory plug-n-play connection that tricks the ECU into thinking everything is OK.
Shown here for the Triumph 675
This allows you to completely remove the servo motor, valve, cables and drop weight but also free up space underneath your tank.
Unclip the plug from the servo and reinstall onto the Servo Buddy, remove the servo and cables and you're done. That's it.
This is a must have when you order an aftermarket exhaust or even if you want to open up your factory exhaust.
Not yet listed on our website, the Servo Buddy retails at $59.95. To place an order simply send Casey a message on the forum or give him a call at 866.931.6644 ext. 822. Is email more convenient? Write us at FORUM at RIDERSDISCOUNT dot COM, and we'll get back to you right away!
