I have a 1995 Suzuki RF600. Here is my problem, after a good ride home I pulled into my drive way and reved the engine to let my family know that I was home. And in that instant the motor stated to idle really sluggish like I flooded it out. The next morning I had fuel all over the ground. So I thought maybe I did just flood the carbs the night before. When I tried to start the motor (with the choke) and it barely ran, when I took it off choke the eng just died and would not start. So carb cleaning I went, now it will only run with the choke but real sluggish no matter how high I turn up the mixture screw. So I cleaned the carbs again and for shits and giggles did a compression test too. I have good spark on all plugs, and compression is good carbs are clean (twice) I was thinking signal generator, or maybe carb balance would fix the problem but not sure.. It will run for a few sec after I take it off choke but it sounds like one of the cylinders is not firing and the exhaust sounds real raspy, then it dies
Any other suggestions or should I go to the shop
