I keep having a problem with my wireless router losing connection. I keep getting a "your IP address has expired" I try and repair it but it can not renew it. So I end up have to disconnect the router from the cpu and plugging the cable line directly into the cpu. I'm only able to get about 2wks worth of time on the wireless before this happens. I had a neighbor come over and re-set my settings right around two weeks ago. Thought everything was good but can see now it's not.
No idea to what the cause is. I just unplug the modem for 30 second's, get it running and reboot the computer then I'm good to go.
The router I'm using is a Linksys WRT54G v2.2
The cpu i have is a basic 2.7 intel 512mb compaq.
When I initially got it I followed the instructions to a tee. The ONLY thing I can think why it's not work is when it asked for what type of secure network I wanted I didn't pick one because it warned of incompatiability. That's probably the reason there.
I figured there were enough computer geeks on here that could help me out.
Thanks!
Thanks!
