1 - 10 of 10 Posts
iv'e been told that i may have a worn cam chain on my zzr 600 e1 but im not to sure its only done 15800 miles.is there anyone out there that can help me resolve this problem? what does a cam chain sound like if its knacked?my bike pull like a train through all the rev's and gears without any wierd noises,but its only when i shut the throttle (under engine braking) when i hear this strange net ticking noise?
please help you teckno wizzes :leghump
I own license2ill
I had a chain wear out at 12,000 miles so it can be your chain. It will make a clicking sound. All you have to do is check your chain with your hand if it moves side to side its time for a new chain. Also check the rollers in the chain they should be solid and not spin with your fingers.
Industrial superstar
valve adjustemnt lately? could be a ticking valve. Otherwise when a cam chain tensioner goes bad you'll know it. It goes and allows the chain to slap around inside and it sounds like yer motor is coming apart. Just so you know all kaw motors i've ever been around have a light clicking to them when they are at idle.
Discussion Starter · #9 ·
would this explain why i only hear this noise when i come off the gas? i know kwaka motor's are generly bullet proof so do you think i should just stop worrying and get on with riding? i was about to sell it and have a 04 sv650s any comments on that?
my 45000 mile zx7 just started making a noise the other night. after 15 passes at the drag strip. :D
1 - 10 of 10 Posts
