High quality turn signals.
OBERON Bar End Turn Signals
$169.00 /pair
Description: Bi-directional LED handle bar mounted motorcycle indicators from Oberon Performance that flash front and back to increase visibility. Available in black or silver.
OBERON Bar End Turn Signals Kit: Ducati 1199 Panigale
$189.00
Designed specifically for the Ducati 1199 Panigale. Instead of using the expanding collet design we created a large hollow
bolt to prevent damage to internal
threads on your handle bar. The additional benefit is an easier installation since the bolt use is much larger and therefore easier to pass the wires through. The hollow bolt also has provisions for a bar end mirror mounts.
OBERON Mini Indicator Turn Signals
$102.00 / pair
Mini LED turn signals that flash front and
back to increase visibility. Available anodized black or silver.
KELLERMANN Micro Polo LED Turn Signal: Chrome
Was: $74.95
Sale: $39.00
KELLERMANN Micro Polo LED Turn Signal: Satin Chrome
Was: $74.95
Sale: $39.00
Don't let the little size fool you, these turn signals are extremely bright!
When we tested these lights it looked like flash bulbs going off...you will be noticed on the road with these turn signals
High quality billet aluminum housing with a very bright LED bulb. They now come with specially designed rubber mounted base, so in case of a crash, the damage to the fairing will be minimal. Very small (2.5"long and 1/3" thick at it's widest point) . 8mm mounting hole.
Sold each individually.
KELLERMANN Micro1000 LED Turn Signal: Black/Amber lens
Was: $67.50
Sale: $54.00
Don't let the little size fool you, these turn signals are extremely bright! These are the brightest LED lights that we have ever seen. It is the only turn signal that is brighter than the halogen.
RIZOMA Turn Signal - Action
$60.00
Characterized by its sharp and marked lines, this compact indicator light has an aggressive look and a high aesthetic value.
RIZOMA Turn Signal - Avio 21
$48.00
Soft, sinuous lines - an indicator light suited to the most diverse styles, from naked to superbike
RIZOMA Turn Signal - Graffio
$60.00
Design with speed in mind, the Graffio indicator light is one more step in the direction of extreme expression.
