THERMO-TEC Adhesive Backed Heat Barrier: 12"x24"
$26.99
The 12"x24" Adhesive Backed Heat Barrier protects parts and components from radiant heat. It can be used in applications to protect painted surfaces, plastic parts, carbon fiber or any component from the damaging effects of radiant heat. This will prolong Carbon fiber finishes and prevent plastic from becoming brittle.Aluminized Heat Barrier is made up of woven silica with a flexible aluminized finish. The highly reflective surface of the material is capable of withstanding radiant temperatures in excess of 2000°F. The adhesive backed composite construction material can easily be applied to any surface or wrapped around a hose or wire to make a clean professional appearance. Perfect for the back of exhaust covers, side farings, belly pans, under seat sections and airboxes or gas tanks to reflect heat. This is perfect for bikes with underseat exhaust system.
THERMO-TEC Exhaust Insulating Wrap: Black 2"
Pricing: $68.99
2" X 1/16" X 50' Black Graphite exhaust heat insulation wrap. New "Carbon Fiber look" graphite black exhaust wrap looks better and resists fluids better than the standard wrap.The original exhaust insulating wrap by Termo-Tec. The Exhaust Insulating Wrap is an innovative way to create more horsepower and reduce inside faring or belly pan temperatures to protect farings. Wrapping headers maintains hotter exhaust gases that exit the system faster through decreased density. Increased exhaust scavenging is produced, along with lower intake temperatures. Exhaust Insulating Wrap withstands continuous heat up to 2000°F, and contains no asbestos. Thermo-Tec exhaust wrap will not over-insulate a system when properly installed due to a proprietary coating developed by Thermo-Tec - Thermal Conduction Technology (TCT) - that conducts heat across the wrap's surface. This coating controls heat build-up and dissipation. Perfect for bikes with belly pans, or bikes with underseat exhaust systems that radiate heat on the rider.One roll contains enough to wrap most 2 cylinder bikes
THERMO-TEC High Heat Wrap Coating: Black
Pricing: $12.99
To finish off a clean and well-protected Exhaust Insulating Wrap application it is recommended to use the Hi-Heat Coating. The coating will protect the wrap from abrasion and harmful liquid spills. Extra resins and binders toughen the surface, extend the life of wrap by protecting it from friction, and seal the pores to minimize the penetration of harmful liquids. The coating also works excellent as a hi temp paint directy on metal surfaces.
THERMO-TEC Snap Strap Kit
Pricing: $36.99
The multi-purpose stainless steel Snap Straps are used to secure the Exhaust Insulating Wrap - and more.The high-temperature stainless steel straps have a narrow profile to fit tight spots, and can be cut to the exact length needed.Snap Straps secure with easy-to-use slide-through fasteners.New precut lengths with tough multi-lock system.
* Register on the Motowheels website for Free forum or lifetime VIP passwords to access discounts on most non sale items. Look for memberships and choose the membership type that fits you the best
