I'd go with the easiest solution first... try replacing the bulbs. Otherwise, check the fuses (although I doubt your brake lights would work if it was a fuse). Next would be to check the wiring.Broker404 said:All of the lights on my 93 FZR600 work fine up front, but the only light in the rear that works is when I use the brakes, the turn signals and normal tail light do not work. Any ideas?
