1 - 7 of 7 Posts
Industrial superstar
Okay so I do alot of steel fabrication and I got some 1" square tube sitting around, What better to do than build my own swingarm stand. Only problem is i need some dimensions. Could I get someone possibly to give me the general dimensions off thier swingarm stand? I would appreciate it a great deal.
Looking around on google check this guys idea out. pretty neat...tube stand
hm... bookmarking it, lets see if I can actualy get the "pins" that have to be on the bike some how to my ride.
Hmmm, not bad if you're in a pinch.
Discussion Starter · #6 ·
Note: for some bikes you may have to use a longer pipe in the back part to make the stand wider. I used two 6 1/2" nipples with a coupler instead of a 12" because with the 12" it was not wide enough for the gsxr. It is more than adequate. I also welded the joints to make them nice and strong. Where he has caps I drilled holes and ran a bolt through with wheels on each side.
Looks cheesy but if it works.......
BTW, the bolts in the spool position don't have to stick out THAT far....the lifting pressure point is right next to the swing arm....there is little if any support at the head of the bolt(in his pics) FYI.
1 - 7 of 7 Posts
