SPEEDYMOTO Ducati 1199-1098-1198-SF-MTS12 Wheel Nut Socket Tool
Price: $69.95
This is the correct tool to properly fit your new Ducati 1098, 1198, 1199, Streetfighter or Multistrada 1200 Axle Nut!
Contrary to what you may have been told a standard socket will not fit properly on your Axle nut. This is because the large axle nuts on the big hub Ducati's have a special inner taper.
◾SpeedyMoto has made this tool just for the Big hub Ducati's, designed to fit perfectly and not ruin your axle nuts.
◾A locator built into the socket keeps the tool from slipping off the nut when tightening.
◾Impact Grade, hardened Tool Steel for a lifetime of use!
◾Compact design makes it an easy tool to take on your next adventure!
SPEEDYMOTO Ducati 748-998, S*R/4RS, HM, 848, Mhe, MTS, M1100 Wheel/Axle Nut Socket Tool
Pricing: $79.95
Speedymoto now offers a double sided axle wrench for all Ducati’s with the small hub, single sided swing arms. The axle wrench tool has both a (hard to find) 41mm and a 46mm socket, fitting both sides of the rear axle.
◾Impact Grade, hardened tool steel for lifetime use.
◾Unique design keeps the tool from slipping off the axle nut when tightening.
◾A more effective and less expensive alternative to multiple sockets.
◾Fits: Monster S2R/S4R M1100, Hypermotard, Multistrada 1000/1100, 748-998, 848, MH900.
SPEEDYMOTO Ducati 899 Rear Axle Nut Socket Tool
Pricing: $69.95
This is the only tool that will properly fit your new Ducati 899 Rear Axle Nut!
-SpeedyMoto has made this tool just for this specific nut, designed to fit perfectly and not ruin your axle nut.
-Industry exclusive locating center prevents slippage
-Impact Grade, hardened 17-4 stainless steel for a lifetime of use!
-Compact design makes it an easy tool to take on your next adventure!
* Register on the Motowheels website for Free forum passwords to access discounts on most non sale items or lifetime VIP passwords for the deepest discounts on all items. Look for memberships and choose the membership type that fits you the best
