Pigeon fart
I'm upgrading our TV so this bad boy needs to go. I bought this about 2 years ago and it retailed for almost $4k. The TV set is in pristine condition with no damage, scratches, dings or what ever.
I do not want to ship this so this is for any of you locals. I put some links on the bottom but if you need any specific information not mentioned here or more pictures of the actual set just let me know.
It works like the day I bought it.
$900.00
Aspect Ratio 16:9
Screen Size 60 inches
Auto SAP Yes
Channel Fix Yes
Closed Caption (CC)Yes
ID-1 Detection Yes
Video Label Yes
Native Resolution 720p - 1080i
Display Resolution 1920 x 1080
Vertical Size Yes
Vertical Center +5 to -5
Tuner 8 VBS, ATSC, NTSC, Clear QAM
Video Processing Yes (WEGA Engine™ HD System)
Color Temperature Cool, Neutral, Warm
Color Correction High, Low, Off
Noise Reduction Yes
Black Corrector High, Medium, Low, Off
Clear White On, Off
Gamma Compensation High, Medium, Low, Off
CineMotion® Reverse 3:2 Pulldown Technology Yes
Direct Digital II Circuitry Yes
Comb Filter 3D Digital Comb Filter
DRC® MultiFunction Circuitry Yes (DRC MF V1)
DRC® Mode High Density, Progressive, Off
DRC® Palette Presets Custom 1
Game Picture +5 to -5
Image Shift Auto, Level 1, 2, 3, 4
Advanced Video Menu Yes
Picture Modes Vivid, Standard, Custom
Color System ATSC, NTSC
Wide Mode Yes
Display Technology 3LCD
Speakers (Total)2
Audio Power Output 24W Total (12W x 2)
Tone Control(s)Treble, Midrange, Bass
Sound Enhancer Dynamic, Standard, Custom
MTS Stereo Decoder Yes
A/V Synch Off/1/2/3
Digital Amplifier Yes (S-Master® Digital Amplifier)
Audio Mute Yes
Speaker On/Off Yes
Simulated Surround Yes
SRS® TruSurround® XT Audio Effect Yes
Dolby® Digital Yes
Channel Label Yes
Channel Skip/Add Yes
Channel Jump Yes
Favorite Channel Yes
Speed Surf™ Channel Selection Yes
Program Guide Access Yes
Auto Channel Programming Yes
Menu Color Yes
Multiple Language Display English; Español; Français
Parental Control (V-Chip)Yes
Info Banner Yes
Programmable Timer 2 Event
Sleep Timer 15, 30, 45, 60, 90, Off
Timer Events Timer 1, Timer 2
Caption Vision On, Off, Program
Clock Yes
Power Save Mode Standard, Reduced, Picture Off
Built-In AC Adaptor Yes
Picture Freeze Yes
Analog Audio Input(s) 6 (1 Front/5 Rear)
Audio Out (Fixed)1 (Rear)
CableCARD™ Slot 1 (Rear)
Component Video (Y/Pb/Pr ) Input(s)
2 (Rear)
Composite Video Input(s)3 (1 Front/2 Rear)
Digital Audio Output(s)1 (Rear)
RF Connection Input(s)2 (Rear)
S-Video Input(s)3 (1 Front/2 Rear)
HDMI™ Connection(s)1 (Rear) with Audio Input
Power Consumption (in Operation)265W
Power Consumption (in Standby)Less than 15W
Power Requirements AC 120V, 60Hz
Power Management Yes
Energy Star® Compliant Yes
Dimensions (Approx) Width 62" (1574mm)
Dimensions (Approx) Height 39 5/8" (1055mm)
Dimensions (Approx) Depth 20 1/2" (518mm)
Weight (Approx.)101lbs 5oz (46.1Kg)
Dimensions (Approx.)62" x 39 5/8" x 20 1/2" (1574 x 1055 x 518mm)
C-Net review [video clip] Hold down the shift key and click the link below.
Sony KDF-E60A20 Projection TV reviews - CNET Reviews
Manufacturer link with more details and specifications..
SonyStyle.com | 60" Grand WEGA™ 3LCD Rear Projection HDTV
