1 - 4 of 4 Posts
Is it really that bad to shift without the clutch. I can do it more smoothly than with it. Also when I up shift and down shift the gears slip right in no prob.
If you are at the right RPM then it will easily switch into gear. I would not recommend it on a normal basis.
Why not use the clutch?
Its gonna REALLY HURT when you trash your trans:)
You can take a shit and not use toilet paper, but I wouldn't advise it either.
RC
1 - 4 of 4 Posts
