Supporting vendor
When you wear high-quality heated gear, your winter rides become much safer and more enjoyable. You cannot replace it with an extra layer of regular clothing or riding apparel. It will only restrict your movements without affecting the body heat conservation much. In extreme situations, slower reaction time may lead to severe consequences on the road, so you’d better choose a lightweight, efficient, modern set of heated gear from some of the most well-respected brands in the industry.
Our online store top-notch heated gloves, jacket liners, pants, insoles, socks, and much more. We have all that you may need for wiring and plugging gear directly into the electrical system of your motorcycle. If portability and convenience are the main priorities, then you can choose battery-powered heated gear for short trips or off-the-bike use.
Highway 21® - Radiant Men's Heated Gloves
Features:
• Lithium-ion battery and controller with 3 heat settings
• Genuine leather construction provides durability
• Hipora® liner is waterproof and windproof while still offering breathability
• 100g of Thinsulate insulation
• Touch Screen compatible
• Armored knuckles for added protection
• Pre-curved fingers enhance comfort and reduce rider fatigue
• Adjustable gauntlet
California Heat® - 12V Jacket Liner
Features:
• Wind resistant, water repellent ripstop nylon
• Very lightweight and highly compressible garment
• Sized to fit snug to your body under an outer jacket
• Pockets on the sleeves to store glove plugs when not in use
• Plugs in the sleeves and accessory plug to connect heated gloves and pants
• Heating elements located on the chest, back, collar, and sleeves
• Power: 77W @ 12V or 6.4A total
• Max Heat 135° F
• Included: battery harness with 15A fuse
FirstGear® - Heated Puffer Vest
Features:
• Made with thermal and lightweight materials
• Fits under a jacket or can be used by itself
• Two zippered hand warmer pockets
• Two internal storage pockets and one additional internal battery pocket
• Built-in, chest-mounted heat controller
• Can be portable with a compatible Li-ion battery using the USB input connector
• Power: DC:5V, Draw: 9W
Tourmaster® - Synergy Pro-Plus 12V Heated Pants
Specifications:
• 100% Polyester wind and water-resistant soft-shell fabric front panel
• Nylon and spandex rear compression panel for reduced bulk and increased comfort
• 100% Polyester microfleece fixed liner
• Thigh to shin flexible carbon fiber heating elements located on front panels
• Heating elements connected using thermoplastic elastomer (TPE) wire for added safety and efficiency
• Built-in waterproof 3-setting LED smart soft touch controller located on the flip-out tab at waistband
• Integrated microprocessor and thermal cut-off protect against power surge and overheating of elements
• 12v DC power / 38.4w power draw / 3.2a current
• Heat settings: high (126°f/52°c), medium (113°f/45°c), low (100°f/38°c)
• Integrated and concealed battery harness and insole/sock connectors
• Includes battery harness and safety fuse
• Hand washable
ActionHeat® - 3.7V Rechargeable Battery Heated Wool Socks
Features:
• Built-In ultra-fine carbon fiber heating panels strategically placed on the top of the toes
• Advanced ultra-fine fibers provide superior heating performance
• Machine Washable using provided mesh wash bag only (gentle cycle)
• Unisex Fit
• Material Content: 70% Cotton & 30% Lycra
Estimated Heating Time:
• High (Red): 140F - 4+ Hours
• Medium (Orange): 120F - 6+ Hours
• Low (Green): 100F - 8+ Hours
How To Use:
• Power Up - Charge the provided ActionHeat 3.7V batteries.
• Plug-In - Connect the batteries to the cords located in the pocket on the top of the sock.
• Turn On - Press and hold the power button on the battery for 3 seconds.
Click on the image to enter the product page for more information.
Press the "shop now" button to browse the full catalog of heated gear at MOTORCYCLEiD.com
If you have any questions, feel free to contact us here or call 888.903.4344 (toll-free) to speak with one of our specialists.​
