1 - 10 of 10 Posts
I'm wondering who out there has used these products for painting their engine. Any suggestions as to which one is better? I found the Rustoleum stuff at Walmart so for convenience sake I might just go with that.
Also for those who have done it, do you pull the engine apart and spray each piece one at a time, or just spray the whole engine in one pass? I would assume if I just spray the whole engine that I should be able to break the bolts free if I need to work on it...
Thanks for any suggestions
· Live to ride
what hastings are you from?
Use Rustoleum its better paint. Make sure it is gas/oil/heat resistant.
I've never painted a bike engine but I have painted a couple vavle covers on cars I pulled them off. I had to replace the gaskets so it was win-win.
Don't pull your engine off or take anything apart.
First warm the engine up hot. Then gunk it using a motor gunk from a auto parts store then wash it down. Wash It good, dry it, mask off what you don't want to paint and spray what's unmasked.
Thanks for the suggestions guys.
I am from Hastings, MN.
Any thoughts on using primer? They make an high heat engine primer, not sure if its worth doing.
Here is where I am at right now with the bike...(the blue line is a bar that i need to remove, the red line is where I want to chop)
And here is a photoshopped image of where I'm thinking of taking it
I love street fighters :)
Use the high heat primer. Reguler paint on bare metel will chip and flake. Primer will hold it on for the life of the bike if done proper.
1 - 10 of 10 Posts
