1 - 3 of 3 Posts
I have a 2001 R6. When I hit the brights, both lights come on, so I know they work. All of my other lights work also. But the running light will not come on. It worked before, but just stopped. Does anyone have any ideas what it might be? I checked all of the fuses under the seat, everything is ok. Does anyone have any ideas? I need to get this problem fixed ASAP. Thanks!
check the actual connections on the headlight, it's possible that it's come loose.
· Midnight Rider
when you say running light, do you mean just the regular head lights? if so, you should check the bulb. they are dual filament bulbs (one for the brights and one for the low beams). so your brights can work, but the low beams can go out.
1 - 3 of 3 Posts
