Set of 2 LED Smart Cap Tire Pressure Monitoring Valve Caps
Ride-On LED Smart Cap Tire Pressure Monitoring Valve Cap
$36.95
The LED Smart Cap Tire Pressure Monitor (TPMS) valve cap is a must for people that want to make sure that their tires are properly inflated. Once installed the LED Smart Cap TPMS valve cap will alert you if the tire pressure drops by a setpoint pressure. The Light Vehicle version of the Smart Cap Tire Pressure Monitor system is availabe for automobiles, SUVs, light trucks, vans, motorcycles, scooters, trailers, ATVs, etc. with a pressure range of 10 to 70 psi and a low pressure warning tr***** of 4 psi (with a +/- 10% accuracy). The Heavy Duty professional grade LED Smart Cap TPMS for fleets and commercial applications is available with a 4 or 8 psi low pressure flashing LED light alarm tr*****, and is suitable for pressure ranges from 30 to 170 psi. The bright red blinking led light will continue to warn you of low tire pressure for more than a month. Great compliment to Ride-On TPS Tire Sealant and Balancer.
  • Easy to Install - Simply screw valve caps onto tire valve stems.
  • Bright blinking LED light that is visible in daylight and night time
  • Self-Calibrating - Automatically calibrates to pressure the tire was set at when the cap was installed. The same valve can be used with tires from 10 psi to 70 psi (Auto and Motorcycle Version with a 4 psi pressure drop alarm) or 30 to 170 psi for commercial version (available in 4 psi or 8 psi pressure drop alarm)
  • Automatically compensates for ambient temperature changes to avoid false alarms.
  • Comes with integrated anti-theft device.
  • Long lasting low pressure alert - blinking red light alerts of low pressure for 750 hours (more than a month)
  • Low battery alarm - the led valve cap will blink yellow for up to 100 hours to alert you that the batteries are running low.
  • Long Lasting 3 year battery shelf life.
  • Great compliment to Ride-On TPS filled tires - 100% compatible and now you can be alerted of a slow leak.
  • Proper tire inflation pressure helps extend tire life.
  • Proper tire inflation pressure helps optimize fuel economy and save up to 3% in fuel.
CAUTION: We highly recommend that the LED Smart Caps be installed on metal valve stems. After installation, rotate the tire to make sure that the LED Smart Cap TPMS does not come in contact with any brake or suspension components (flex valve stem side to side and allow a minimum of ¼" clearance). The valve stem and LED Smart Cap should NOT protrude beyond the tire where they may come in contact with curbs or other objects. Metal valve stems are recommended because rubber valve stems can flex more, become brittle, or fatigue and crack over time.
