ninja shadow warrior
on b12s rear shock,the stock setting is 4 of 7. i have not fiddled with it since i bought it.
i would like to firm it..i'm 205lb.
should i go up on the collared steps or down?? looking at shock from the left side?
\----XXX <now>
\----??? :confused:
If there are numbers, turn it to a higher number. If no numbers, turn it so that the spring is compressed more not less. Make sure you stop in a detent. HTH
