So my issue started after letting my bike sit for about a year. Every month I’d drive it around the block to keep the battery charged, but no further. Last week, after trying to start, the bike wouldn’t budge. The starter would click, fuel pump would prime and engine would crank but it still didn’t start. On top of that, the headlights and horn stopped working as well, which I’m pretty sure happened at the same time, so they’re related. I’ve tried changing the spark plugs and cleaning the fuel injectors, but still no luck. If any mechanics know what could be wrong, please let me know, any help is appreciated. Thanks!
Also, I changed out the battery already so it’s not that.
My bike is 2015 Yamaha R3.
Have you checked fuses? Also check the simple things like side stand switch or kill switch ??
What are your battery readings ? Ignition off .. ignition on .. cranking levels ??
