1 - 4 of 4 Posts
Is the PC for our bikes meant only to be adjusted without the bike running? I know the install instructions say to only install when the ignition is off. I thought because of the fact that the 9V adapter was included that we are not supposed to hook up to the PC with the bike running.
Livin' on the Edge!
As long as you have a computer that is beside the bike, you can adjust with it running. You just make adjustments and then send the map. if you want to use the control panel on the power comander itself, you can do it with the bike runnig also but are limited to being able to bump up or down on the 3 ranges (low, mid, high)
1 - 4 of 4 Posts
