I'm not sure if this is a problem or not but I just noticed it a day ago and I am pretty sure it wasn't there before. I have a 03 636 and I was riding around for awhile. I stopped for alittle and went to move my bike about a half hour later. When I started it up all the lights on the bike (Tach, headlight, taillight) are flickering pretty noticably with the engine at idle. They don't go out but they do flicker. If you increase the revs it will go away slightly but return at idle.
So I go for a ride alittle later and stop but leave it idle and no flickering. As soon as I shut if off and turn it back on the flicker is there at idle until I ride it. While I'm riding there is no flicker. It is almost like the stator is messed up and isn't charging right. I've never noticed it before, but its weird because if you ride it like 500 feet and stop the flicker is gone until you shut if off and turn it back on.
I'm not sure, I'll probably run it by the dealer but just wanted to see if any of you guys have any insight on it.
Thanks in advace!
Thanks in advace!
