Hello all,
I am in the process of working through a 1986 Ninja 600R that has been out of service for about 3 years. The previous owner routed a fuel line from the petcock to an on off fuel valve for what I am assuming was a leaky petcock. The problem that I am having is determining which line goes where. I have all the vacuum lines in place but I do not know where the fuel line should be routed. I have attached photos in hopes that someone will have this info. The petcock has 2 ports, the tank has a port that is on the bottom and has an electrical pigtail for the gauge. I have also located a port on the top of the tank that sits below the left side of the seat and another below the airbox. Any help with this would be appreciated! Noel
