Gottcha...if I am in 6th gear....I am not going 60 that is for sure so I can't help you there. But is 6th at 80...I am usually at about 7 grand.Zippy said:ok, my B, in 6th gear.
Down one in the front and up three in the rear? I turn 6k at 80 in sixth gear. I was under the impression that such an aggressive sprocket combo would send RPMs through the roof at such speeds (was thinking 9k or so).kawagirl said:Gottcha...if I am in 6th gear....I am not going 60 that is for sure so I can't help you there. But is 6th at 80...I am usually at about 7 grand.
bone-stock mechanically. It has 5600 miles on it. Is 6k too high?SyntheticReality said:What else is done to your bike, Zippy? How many miles?
KawZX7R said:my 01 in 6th going 80 is a little less than 6k and about 70mph im at a little over 5k i have 15 tooth in front, im getting 2up in the rear soon i hope, the sprocket is on back order
really easy, you pull one case cover off, unbolt the old one, throw the new one in and replace the gasketKawZX7R said:How hard is that ignition advancer to install?
