I have seen some gixxers that have only half of the headlight assembly lit up... is there a way to only get one bulb for low beam and add the 2nd for high?????
The low and high beams are in the same bulb. You'd have to wait for the low beam filament to burn out. Too bad this thread wasn't around a few months ago, both of my low beam filaments burn out, leaving me with only high beams. I'll check and see if I still have the bulbs.02gixxer600 said:Sounds like i need to change my assembly out for the 2001 if i really wanted to go through with it....
It kinda sux cause if I pull my low beams wouldn't that mean... no low beams? or are both low and high on same bulb. or whats the deal?
