1 - 6 of 6 Posts
what type of oil is best for my 2001 r6 (completely stock bike) the previous owner used Motul should i stick with the same stuff or does some one have another type that is good and what weight (ie. 10w30 ,etc)
I use to use Yamalube 20W-40, but now I use Shell Rotella T 15W-40. If you change your oil regularly and are only doing street riding, that'll be fine for you.
I've been using motul for years on several bikes and will stick w/motul since I have not had any issues using their oil.
put whatever your owners' manual says into it...
As long as you keep it changed regularly and don't use an energy conserving oil (10w-30 or thinner is not optimal for wet clutches), then you should be fine.
I run Mobil 20w-50 (summer) or 10w-40 (colder months) and I haven't had any problems.
1 - 6 of 6 Posts
