+1roadracer319 said:Amsoil 10w40
Where do u get the Mobil 1 MXt4 oil? Nobody carries it around here.YammyR1 said:I actually run both, depending on the current sale. 10w-40 Amsoil or Mobil MXT-4. Change about every 1500-2000 miles.
Thanks, but I am doing a little research, and would like more uptodate results. I did review the search that you provided, and did the same one as well.SVBeest said:Hey look, the search function is still active on this forum!!!
http://www.sportbikes.net/forums/search.php?searchid=369548
Believe it or not, I saw it at one of the local Wal-Marts the other day. It wasn't with the other motor oils .. it was off by itself near the other motorcycle stuff .. helmets, etc.Travis71902 said:Where do u get the Mobil 1 MXt4 oil? Nobody carries it around here.
sounds like you got a new bike, update your profile... "None at the moment."fordfasterr said:I use Pennzoil 10w40 regular car oil...
Here are some other posts about this and lots of links to off-site research...
http://www.sportbikes.net/forums/showthread.php?t=287984
POLL ^^^^.
I plan to do the oil changes every 2k miles... So far I only have about 750 miles and I've already changed the oil twice...
Just to get those break-in particles out of the engine ...
