Sat for 3 days, came back and had 1 failed attempt at the engine turning over then nothing. Doesn't click, from fuel pump or starter, no power to headlights, nothing.
Was riding daily prior so kinda weird
-Replaced starter relay, not that
-Charged battery, not that
-Pulled off starter and checked brushes, surprisingly clean and a lot of life on brushes
-Going to try looking at fuel pump tomorrow but not sure what to do/look for...
I tried putting it in gear and shoving my feet back to 'push start' or whatever and I did get my lights to come on and some signs of life for a split second but then nothing. And she hasn't whispered since. Please help. I love this bike so much
Thanks
Sent from my Pixel 2 XL using Tapatalk
Sounds like the switch haveing a short in it jump the two ignition wires in the back of the ig option switch se if the lights and hages dont light up back of the connector of the ignition switch run two small screws between the two main red n black I think cant miss them same color and there the bigest jump the wires see if she lights up if so you got a short in the switch or bad connection to the switch oh ya and check the fuses if theres any blown
