Look in your Temporary Internet file folder. There is also a 'Temp' file folder it may be in, if not in the previously mentioned one.
I have XP i go to C: then to doc and settings, then to the login name folder but there is no temp, or temporary internet files folder? COuld this be named anything else?Baldman said:I had a minute to check. If it is a movie file you played with Windows MediaPlayer - it is located in your C://Windows/Temp file. If you have Windows XP, the location is slightly modified to - C://Documents and Settings/yourloginname/Temp.
Yeah, just select START, Search, and type 'Temp'. When you see the folder, select it and inside you should find your .wav, etc file (as long as you remember part of the name it will be easier to open the Temp file and then depress 'Ctrl + F' (item FIND) and type in the part you remember. Every instance of the word(s) you input will be displayed and you can choose the next iteration by depressing ENTER.Krunk16 said:I have XP i go to C: then to doc and settings, then to the login name folder but there is no temp, or temporary internet files folder? COuld this be named anything else?
Thanks much for the help fellas im just lazy but I still wanna know these things heh.
