1 - 12 of 12 Posts
After installing the Two Brothers Racing pipe with no Cat and putting in the Power Commander PC3 usb with custom map, my engine now surges when idle. When I monitor the rpms at idle, they will bounce from 1000-1500 rpms. Using the PC3 software, how can I adjust the map to give me a more consistant rpm idle speed? I want to stay around 1400 - 1500 rpm's unless that is not a good idea. Thanks.
Try adjusting the idle to spec. 1250-1350 rpm. I suspect that the PC is trying to compensate from a too low idle screw setting.
I'd get the idle set to factory specs with the PC out of the loop, then test the results. I don't remember at what RPM the PC kicks in, but if your idle is set at 1400-1500 you may be running into a point where the PC is adjusting the fuel when there isn't throttle input yet...just a thought...
Discussion Starter #4
My question is "how do I set the idle?" I'm not sure how to do it and the Power Commander instructions are very vague about all the settings and what they mean.
Not with the PC. From the left side of the bike near the top spar of the frame is a big idle-set screw (phillip thread). Turn this until you get the correct idle. Also, have your throttle bodies been adjusted yet?
Discussion Starter #6
Ok, didn't know that's how to set the idle. No, I have not had the trottle bodies adjusted since I bought the bike. Is this something I will need to have done?
This is a periodic service item. Generally done on the intial break-in service and every 8000 miles (if I remember correctly) from there. It will affect idle which in turn could have an impact on your surging issue. All speculation though :)
Discussion Starter #9
I ended up playing with the idle just now and have it set for around 1100-1200 rpms. 1400 - 1500 was too much. Went for a short ride and it acts much better too. Bugduc, I took out the small screens in the back of the pipes. Were they suppose to reduce the noise or is it a flare reducer?
Discussion Starter #11
The surging was still happening in that rpm range. If that is the factory specs, then I guess I will have to have the throttle bodies played with as well. What does something like that cost at the shops?
Simply for decibel reduction.
1 - 12 of 12 Posts
