1 - 4 of 4 Posts
im an idiot and dont know what im doing and need some help. I pulled the clutch in and the clutch lever sorta broke. its still attached to the bike but i need to get it off to see what hell happened. if its the cable that just got disconnected how do i fix that and how do i get the lever off. sorry for the retarded question.
Discussion Starter #2
ignore my first post. the cable came out, and no for another dumb question how do i reattach my clutch cable. thanks!
Look on the bottom of the lever, there should be a pretty obvious place to fit the cylinder thing on the end of the cable.
second chimp in space
you have the little thumb nut to adjust the tension on the cable. Turn this all the way in, to give yourself as much slack as possible. also orient it so that the slot in the side ligns up with the slot in the holder and the slot in the lever. Then just take the cable and fit it in the slot, and with the extra slack available, just fit the cylinder on the end of the cable into its slot in the lever.
This is sounding a lot more complicated than it really is...
1 - 4 of 4 Posts
