New batch of colorful Oberon slave cyliders just landed
OBERON Clutch Slave Cylinder: Ducati
$153.00 FREE Shipping
For better performance and reduced clutch lever pull. Available in six colors.
Oberon Performance clutch slave cylinder. Designed to improve the performance and looks of the original Ducati cylinder. Substantially reducing the heaviness of the original clutch action, aching arms and clunky gear changes are a thing of the past. The internal piston design, seals and breather hole have been drastically enhanced to stop leaks and leave a smoother clutch action. CNC machined from billet for lightness, strength and precision looks. The 29mm piston size is much easier to find neutral while still having an easy clutch pull. Everything you need is included in the kit plus a conversion shaft for earlier Ducati's.
UPDATE: Oberon has updated the slave cylinders to work with the newer 2011/2012 bikes that have a pin to stop the rod from spinning. You won't need to remove the pin, there is now a recess built into the slave cylinder.
Smoother transition resulting in lighter clutch action
Available in six anodized colors
Black, Blue, Gold, Red, Silver and Titanium
CNC machined from billet aluminum
Repositioned breather hole away from chain and sprocket grime
'U' seals for precision action
Wiper seal to stop dirt ingress
Shaft and dust sealed back
Pre-2000 conversion spacer included
Simple to install
Stainless steel fasteners
1 year warranty
Add MOTUL RBF600 Racing Brake Fluid 0.5 liter as an option when purchasing this Oberon Slave Cylinder for only $12 ($21 value).
* Register on the Motowheels website for Free forum passwords or lifetime VIP passwords to access discounts on most non sale items. Look for memberships and choose the membership type that fits you the best
