1 - 14 of 14 Posts
Was wondering what would be better? Having the rubber frame sliders, of thick metal frame sliders. My friend gave me a set of custom metal frame sliders which are rather THICK!! But was wondering on what the majority of you all would think. Thanks.
Metal does not slide well against the asphalt. Instead, due to the hard composite, I've seen a couple of them put a dent on the frame.
Use plastic frame sliders. I've crash tested 3x to know they work well. :D
metal ones can also break engine mounts if the bike is dropped hard enough
Ha, I see you are learning Rob. You should try to avoid metal frame sliders. Composite or Delrin sliders work the best. You want the material to absorb the impact so the bike does not flip. And as said before, metal can spark.
You will be missed Shawn
i personally do not think metal of any sort would be a good idea. just my .02. just go w/the plastic. I mean unless your bike is a show bike which is never ridden.
1 - 14 of 14 Posts
