YIKES!!!
Never compramise on the rubber you have on the bike. Generally OEM tires are nothing too hot. On some bikes there pure rubbish. I've learned the hard way with tires, always get the best you can afford. The skin you save will be much more expensive than the few bucks you save on a cheapo tire...
Also, be sure the tire manufacturer says the particular tire is ok for your make/model of bike. Some bikes can be really squirrley with mix/matched tire combos.... I once had a very triangulated dunlop front and a round metzler rear and my GSXR was so dam squirrely it was spooky to ride above 45mph
Also some tires are notorious for being "crack sniffers" tires that act weird when they encounter a crack in the road....
Best tire I've found for $ to miles ratio and being a consistant top performing tire has been Bridgestones Battle Axe, the worst Michelin or Dunlops..... Battle Axes have gone well over 5000 miles for me while I've never seen a dunlop go over 1800 yet the performance between the 2 is so close unless you are into championship racing you will never notice the difference except in how much more drunk you can get because you still have that 200 bux ya saved on the Battleaxe
