Magnecor 7mm Ignition Cable Set: M600-900 / M620-900ie / MH900e / Supersport 620ie / 800ie / 750 / 900
$41.00
Magnecor 7mm Ignition Cable Set: M695 / S2R800
$47.00
Magnecor 7mm Ignition Cable Set: M696 / 796 / 1100 EVO / HM 796 / 1100 EVO / MTS 620
$47.00
Magnecor 7mm Ignition Cable Set: Monster 1000
$169.00
Magnecor 7mm Ignition Cable Set: Monster S2R1000
$172.00
Magnecor 7mm Ignition Cable Set: Sport Classic / HM 1100 / M1100 / MTS 1000 / 1100
$169.00
Direct replacement for 7mm original equipment carbon conductor wires.
Conductor provides exceptional RFI and EMI suppression to permanently eliminate the typical performance and fuel-wasting spark energy deterioration of OE and aftermarket carbon conductor wires. Also overcomes performance problems associated with poorly suppressed aftermarket spiral conductor wires on both modern and older engines. The conventional style insulating jacket consists of EPDM insulation and an extra strong EVA outer jacket for better terminal retention needed for small diameter cables.
Kit Includes:
Black 7mm wires to replace all wires from ignition coil to spark plugs, includes boots and caps.
Magnecor 8mm Ignition Cable Set: M695 / S2R800
$49.00
Magnecor 8mm Ignition Cable Set: M696 / 796 / 1100 EVO / HM 796 / 1100 EVO / MTS 620
$49.00
Magnecor 8mm Ignition Cable Set: Monster 1000
$171.00
Magnecor 8mm Ignition Cable Set: Monster S2R1000
$175.00
Magnecor 8mm Ignition Cable Set: Sport Classic / HM 1100 / M1100 / MTS 1000 / 1100
$171
Conductor provides excellent RFI and EMI suppression to permanently eliminate the typical performance and fuel-wasting spark energy deterioration of OE and aftermarket carbon conductor wires. Also overcomes performance problems associated with poorly suppressed aftermarket spiral conductor wires on both modern and older engines. The conventional style insulating jacket consists of high dielectric strength silicone rubber insulation, fiberglass reinforcing braiding and a high temperature, high tear strength silicone rubber outer jacket. The flexibility and ruggedness of the cable allows it to be fitted into original 7mm cable holders.
CONDUCTORS:
The above Magnecor cables feature versions of Magnecor's Metallic Inductance EMI Suppressed Conductors, specially constructed to best suit the applications for which the cables are designed. See documents tab for more detailed information.
Magnecor ELECTROSPORTS Series Ignition Cables are intended for use as factory replacement wires on both the most recent engines with computerized management systems and older engines with carburetors and/or mechanical fuel injection. Engines used in marine craft and commercial vehicles, as well as industrial stationary engines will also benefit from the use of these cables.
Kit Includes:
Blue 8mm wires to replace all wires from ignition coil to spark plugs, includes boots and caps.
Magnecor KV85 8.5mm Ignition Cable Set: M695 / S2R800
$52.00
Magnecor KV85 8.5mm Ignition Cable Set: M696 / 796 / 1100 EVO / HM 796 / 1100 EVO / MTS 620
$52.00
Magnecor KV85 8.5mm Ignition Cable Set: Monster 1000
$197.00
Magnecor KV85 8.5mm Ignition Cable Set: Monster S2R1000
Price: $204.00
Magnecor KV85 8.5mm Ignition Cable Set: Sport Classic / HM 1100 / M1100 / MTS 1000 / 1100
$197.00
Magnecor's KV85 Competition (8.5mm) Ignition Cables feature Magnecor's exclusive 2.5mm high capacity Metallic Inductance EMI Suppressed conductor consisting of stainless steel wire precisely wound at 200 turns per inch over a ferromagnetic core. The insulating jacket is made entirely of Magnecor's exclusive TC-1500-HS high strength aerospace grade silicone rubber, and its single layer construction will prolong the jacket's insulating ability by conducting extreme heat away from hot-spots that occur near over-the-limit heat sources.
The KV85 8.5mm jacket has a service heat resistance of 600 degrees F (320 degrees C) and up to 1,000 degrees F (540 degrees C) for short burst 3 minutes. Even if limits are exceeded, the silicone rubber will retain its insulating ability until wires are removed from engine.
Magnecor Race Wires are primarily designed and constructed to be used in applications where it is essential to prevent the possibility of ignition wires compromising engine performance. Modern race engines, modified street engines and stock street engines which rely on electronic devices to control the function of either or both the ignition and fuel systems are prone to interference from all other spiral conductor ignition wires sold through performance parts outlets, none of which can provide proper suppression for EMI, particularly if a high-output ignition system is used.
Kit Includes:
Red 8.5mm wires to replace all wires from ignition coil to spark plugs, includes boots and caps.
* Register on the Motowheels website for Free forum or lifetime VIP passwords to access discounts on most non sale items. Look for memberships and choose the membership type that fits you the best
