A chain is made of steel, and eventually that steel just gets streched out from an engine pulling it arount and around. Its just happens.
To adjust it you will need a rear stand (either buy one or find someone with one). Put it up on the rear stand, loosen the axle nut and give it a little tap it so it isnt scratching against the swingarm when you tighten the chain, loosen the outer nuts at the ends of the swingarm and tighten the inner ones. It will pull the wheel back and tighten the chain up for ya. Then check the tension in multiple places by rolling the wheel (while still on the stand, of course). It should only move 1 inch total (half up, half down) in the middle. When thats good, crouch behind the bike and rooll the wheel again. Look at the top of the chain and see of if it is angles of turning a bit. It shouldnt. All those bright shiny pieces in the middle should be in a perfectly straight line while you are turning the tire. That aligns the tire. When thats all done, tighten the axle to 75 ft.lbs., and tighten the nuts at the end of the swingarm.
If the chain is clean and lubed, go and have fun.
