so here is my situation... i have an 01 R6. when i bought it there were flushmounts installed so i have no idea about brand or wire hookups. for some reason my right turnsignals don't work.
i checked the fuse and thats fine. i think it is something with the front flushmount. there are 3 wires: black, green, and blue on the bike. i tested them with the voltmeter and i found out that the blue - positive, black - ground, and green - signal wire. on the flushmount there is red, black, and black w/ stripe. i assumed red - positive, black - negative, stripe - signal. when i connect the red and black only the running light comes on. when i connect the red, black, and stripe the signal light is constantly on, but not flashing. and i can take the black off, leaving just red and stripe and that same thing happens. when i connect the black and stripe, i get no lights. that is ok with me but the weird thing is, i can't get the signal to flash ever. i push it right and nothing happens. and the weirder part, i can't use the left signal for a minute or two. my left signal works fine after that break, or if i don't touch the right signal first. if anybody knows what the hell is going on, can you let me know? thanks.
