1 - 10 of 10 Posts
i just have a few questions just to see wut different answers i can get out of u guys. alright here we go
What pressures are u runnin in your tires?
What oil do you use?
What chain lube do u use wax or regular?
What do you use for cleaning purposes?
How often do you change oil?
How often do you change plugs?
RTFM
sorry.....
34f/37r
Motul dino 10W-40 oil, OEM Suzuki filters
Scottoiler auto chain lube
Dish washing liquid in warm water plus Motul biodegradable bike wash
3500-4000 miles, filter changed every oil change
15,000 miles or when needed
Your bike may be different.
42 psi (alittle high but that's how I like them)
motul changed every 2-2.5k miles
chain wax
water, soap,
inspect the plugs every 6k miles and change when needed or at 12k, 24k miles etc...
read the f'n manual
What pressures are u runnin in your tires? Cannot remember - I am in Iraq
What oil do you use? ProHonda
What chain lube do u use wax or regular? Usually a spray lube
What do you use for cleaning purposes? ProHonda Sprap/Polish/Cleaner
How often do you change oil? every 2k miles w/ filter change
How often do you change plugs? 15k miles or when needed
I own license2ill
Tire pres. some where in the mids to high 30's
OIl I USE Yamalube.
Chain. Latley I have been using oil.
Cleaning Every thing from Mothers
oil change 2 a summer at the beginning of summer and in the middle of summer
Plugs Never hade to in 30,000 some odd miles.
F-You and Yourspace!
What pressures are u runnin in your tires? - Different tires, different pressure, different riding, different pressure. I use whats required at the time.
What oil do you use? - Motul 5100
What chain lube do u use wax or regular? - PJ1 Blue lable
What do you use for cleaning purposes? - Simple Green / Soap + water
How often do you change oil? - Every 3000 miles
How often do you change plugs? - Every 6000 miles
1 - 10 of 10 Posts
