1 - 20 of 20 Posts
Hey guys just figuring out my new to me 01 cbr600F4i. I hear a rattle coming from the bike when Im cruisin at about 5,000 to 6,000 Rpms. If I accelerate the noise goes away if I shift into a higher gear the noise stops untill im at 5,000. Ill pay attention to the noise tonight for a better description. Ive never owned a sportbike before maybe its normal dont know?
Thanks guys
Man, I am glad to hear your problem (well, not glad you have it) because I just bought an '02 600 F4i and I have the EXACT SAME issue. I don't feel any performance issues but as CASHFLOW911 stated, there is a strong vibration (mine isn't too much of a rattle as cashflow911 stated though) between 5,000 and 6,000 RPM's. If I accelerate up to 6,500 RPM or decelerate down to 4,500 RPM';s the vibration goes away. Is the CCT known to make noise at certain ranges of RPM or would we hear it all the time?
Thanks
Yes, it only makes noise around 5-6ish. Its definately the problem. I am going to do mine this week or weekend and will take pics during the process. This forum has helped me out in the past, just wanna give a little back ;)
As others have mentioned, the noise is due to the cam chain tensioner. Mine also rattles between 5000-5500 rpms. I have a APE tensioner that the previous owner gave with the bike but I'll wait until the noise gets worse or maybe this winter to install it. I've heard good and bad things about the APE; just don't overtighten it.
Mechanically, the CCT thing isn't really an issue. That's probably one reason why Honda hasn't done anything about it since it is a very common problem. It's just an annoying sound when you're cruising at that RPM.
From what I hear from most people, its just an annoyance. Most say it doesnt loosen enough to skip a tooth but im sure there's a slight slim chance. I installed the APE and didnt tighten it good enough i guess cuz i hear it again. It doesnt bother me anymore so im not gonna worry about it.
El A MC Rider
My '01 F4i only had 1,800 miles when I bought it (May '04) from a guy who had it stashed in his garage collecting dust. After a couple weeks of riding, I noted a rattling noise that began to annoy the hell out of me, so I took it to the dealer (LA Cycle Sports). The CCT was identified as the culprit and changed. Rattling noise went away and the bike seemed more responsive. I'm looking at my invoice now and the cost was as follows:
CCT $45.96
CCT Gasket $1.65
Labor $90 (1.5 hours)
Got an oil/air filter/coolant/spark plug change while I was there so the end bill was a doozie, but it was worth it.
Dropped the bike off first thing in the morning and waited while it cooled down before the mechanics went to work. Had the bike back within 2 hours.
Labor was a bit steep and I'm sure some mechanically inclined folks can do it for you cheaper, but peace of mind, to me, is priceless.
Getting new tires next.
Good luck.
i just bought an 02 cbr 600 f4i with 6000 miles on it and it was rattling already, the tensioner is like 60 bucks and easy to install with the right tools, 1/4 drive allen head sockets especially and a swivel adapter, it taked a few hours since you take off the tank and losen up soem fairings but still simple, i figuered it out by myself, and no manual.JUST FIX IT......i use to have a 98 zx6r ninja, my first sport bike and i heard the rattle but did know what it was, i kept running it and it ended up stretching the chain, i couldnt fix that so it cost around 500$ for to have it fixed, the tensioner, chain, gaskets and whatever else. so i reccomend havin them fixed as soon as possible.
Ghost GTO
Okay, so we all know we have a CCT on our CBRs.
But is it a MANUAL CCT? Or an AUTOMATIC CCT?
What is a APE MANUAL CCT? And what is the benefits of having an APE?
Why should I go with an OEM if the OEM is making the noise?
Thanks,
Jon
My new 2001 is making this exact same noise. It's annoying:(
1 - 20 of 20 Posts
