1 - 8 of 8 Posts
factory pro ignition advance rotor? Anyone have any experience with these? If they do what they claim then it sounds like it may be worth it
Are we not men?
Why not spend the money becoming a better rider?
Enlightened
I installed one on my '03 Z1000. 4° timing advance. Very easy installation and it did provide a noticeable low/midrange performance boost. Nothing dramatic, but still noticeable. If you're not running premium fuel already you'll probably have to after the install.
I have a mechanical ignition advancer in my Speed Triple, set to 5 degrees advance, and there is a noticeable increase in low and midrange torque. I have had a TuneBoy for a while that will advance it through the ECU, and have to incorporate the 5 degree + when creating tunes. Maybe the PC 3 has the same application?
Discussion Starter · #6 ·
Not quite sure what this has to do with becoming a better rider. it claims to give better low/midrange, and i was checking to see if anyone has installed one and if it did what it claimed.
thanks for the worthless post
Are we not men?
It's not a worthless post. Unless you're racing at a fairly high level, you aren't getting all of what your bike can serve in stock form. Hence becoming a better rider.
edit: Sorry, Valentino. I didn't mean to insult you.
Discussion Starter · #8 ·
I try to become a better rider everyday, however getting more out of the low/midrange(which i see alot more of dealing in traffic than the higher ranges) would be a nice thing. sorry if i took your post the wrong way, just wanted to see if they do truely give you what they claim, because for 50 some bucks, it seems worth it
1 - 8 of 8 Posts
