around how many miles do u guys get before you are on low coolant because my 05 gsxr750 has 3400 and it's on low. and its the second time already, and my horn doesn't work so what to do?
See if you can find where it's goin. On the horn note, make sure its hooked up. Sometimes mine gets disconnected somehow. It just has some plug on connectors. Don't know if yours is like that but worth a shot.
Check to see if you have any leaks...ride the bike for a little bit and then keep it running and look around for a leak..if not a leak it is probably something expensive.Something is definately wrong after two times...that's for sure! :idea
Take it to the dealer and let them handle it. You should not be adding coolant unless there is a problem. If you don't see any drips on the ground or leaks, watch your oil for a milky look.
