Plunder, THEN burn!
** sold **
** sold **
I have a leftover front Heindl stand from the group buy that we had. This is a NEW STAND. Never used.
Heindl Engineering Front Stand: Our Front stand fits most all major models of sporkbikes. Heindl Engineering uses a unique angle bracket to support the front forks simultaneously from the back and bottom sides. This makes our front stand extremely stable. The angle brackets are covered in 1/16" thick protective rubber to prevent scratching of your forks.
Larger picture here
Key Features of all Heindl Stands:
• Designed by an experienced mechanical engineer
• Manufactured from heavy wall 1 1/2 inch diameter steel tubing
• Grade 8 hardware for superior strength
• 3 inch solid polypropylene wheels
• Powder Coated for increased durability
• Fully MIG welded construction
• Protective rubber coating on contact points to prevent scratching
These stands will support even the heaviest of sportbikes for extended periods of time!!
Please note: Never use a front stand without first putting the bike up on the read stand. You must use a rear stand with this stand.
Refer to http://www.heindlengineering.com/ for details.
Regular price is $75 + $20 shipping. Your price $68. I will hook up with you if you are in the area and save you the shipping. Otherwise I will slap it in a box and charge you actual shipping , prolly about $15.
