1 - 3 of 3 Posts
Assuming the bulb type is the same as stock, how does the wattage compare? If the standard bulb wattage is way less than 55, you might have a problem supplying 55W continuously causing something (socket, wire, housing etc) to burn.
Thanks for the response Ray and sorry for not following up haha. It does work just fine, but haven't dared start up with highbeams on.
1 - 3 of 3 Posts
