1 - 6 of 6 Posts
I have a problem with my 2002 zx9 that the dealer has not been able to figure out. Maybe you guys can help.
Under certain conditons (usually high rev or hitting a big bump) both headlights go out totally (no hi or low beam but the city light still works) unitl I come to a complete stop or bring the revs down low. The headlight switch also no longer works when this happens. Has anyone seen or heard of this problem and have a fix? The dealer states that he double checked all connections, etc. and even put it on the dyno and could not reproduce the problem. This has happened a couple of times an NIGHT. I've changed the junction box and both headlight relays and the problem still exists.
TIA
Have you tried replacing the bulb? If the filament is loose, it may go out when the bike hits a bump or the vibrations from the RPMs get high.
I had alomost an identical problem, it just seemed more intermittant. Checked everything but every time I tried to test it, it worked. I finally decided to change the nearest connection. (lots of wires) I went to Radio Shack and bought a 12 PIN connector. Problem solved!!!!!
P.S. I shook that wire harness a million times trying to find a loose wire to no avail.
Steve Krytus
Steve Krytus
What connection did you actually change? The one closest to the headlights? Did you just splice in and change the connector?
1 - 6 of 6 Posts
