1 - 5 of 5 Posts
i have a 97 gsxr 750 that i just replaced the engine on. i have reconnected everthing as it was and now it wont crank. i have had the coils, wires, ecu, module, and fuses checked, i have also replaced the magnetic pickup on the crank and still nothing. there is gas going to the carbs. when i check the plugs for arcing i get nothing. can anyone please help me or try to tell me what i should do next without having to send it to the local shop for work. thanks for the help all.
~ Master Technician ~
Check you safety switches......side stand, nuetral, tip over, run/off ect...
Sounds like you might need a new stator....
1 - 5 of 5 Posts
