1 - 4 of 4 Posts
I have an 02 gsxr 1000, so I think its the same as the 01-03 600's or something so I'm sure someone will know whats up here.
I can't adjust my headlight! When I turn the adjusters, nothing happens. Also, the headlight is loose and shakes when I'm going down the road. I can push on the reflector within the housing by where you put the bulbs in and it'll move pivot around almost a half inch. Do I have to take the whole thing apart to get to the problem?
Can't you just tighten the bolts around the headlights?Have you been able to adjust the headlights before?You might just be able to go out and get new adjusters.
Discussion Starter #4
dragracer1951 said:
I think the adjuster screws are backed out of the adjusters...Take it apart and reassemble...
Jim
that's what I figured.
1 - 4 of 4 Posts
