1 - 8 of 8 Posts
Engine: 487 cc, four-stroke, twin cylinder, air cooled with DOHC
Bore/Stroke: 74.0 x 56.6 mm
Compression Ratio: 9.0:1
Carburetor: Mikuni BSR34
Lubrication: Wet sump
Ignition: Transistorized
Starter: Electric
Transmission: 6-speed
Final Drive: #520 chain
Overall Length: 2080mm (81.9 in.)
Overall Width: 820mm (32.3 in.)
Overall Height: 1080mm (42.5 in.)
Seat Height: 790 mm (31.1 in.)
Ground Clearance: 150mm (5.9 in.)
Wheelbase: 1405mm (55.3 in.)
Dry Weight: 173kg (381 lbs.)
Suspension:
FRONT: Telescopic, coil spring, oil damped
REAR: Link-type, 7-way adjustable spring preload
Brakes:
FRONT: Single hydraulic disc
REAR: Single hydraulic disc
Tires:
FRONT: 110/70-17 54H
REAR: 130/70-17 62H
Fuel Tank Capacity: 20 liter (5.3 gal.)
not to be picky, but you should state that the BSR34 is 2001+... I do believe.
before that the carbs did not have a mid-main.... which they have now....
I'll see if I can dig up the specs.
Gs500f 2005..having issues bike started ..with the throttle half way it was running at almost 2rpm then it turned off now it wont start .. I also reoplaced the fuel line
I suggest you post the question on gstwins.com
That site is extremely active with hundreds of posts about GS500's every day. There are active people there that rebuild bikes and a couple even assembled bikes from spare parts and have a showroom quality bike.
Its free to sign up.
1 - 8 of 8 Posts
