1 - 5 of 5 Posts
im having trouble finding a gel battery for a 2003 r6. i find them for 2006 and up would that also work for my bike.. im talking about trugel..
Nope, but they look to be the best price on this newer tech
You can find your standard batteries size, then fit one of these. They are much smaller, so you can even go more capacity
Batteries plus website will probably have your bike
Sent from my Motorcycle iPhone app
Looks like the AM8-01 would work.
Dimensions 114MM (4.5”) W x 60MM (2.36”) L x 100MM (4”) H
XTA9B-BS Xtreme AGM Battery 600CC 2001 to 2007 YZF-R6 Yamaha Motorcycle
Item number: XTA9B-BS
Weight: 5.6600 lbs
Voltage: 12V
Capacity: 8AH
CCA: 110
Batteries Plus XTA9B-4 Battery Replacement
UT9B-BS Battery Specifications:
Voltage: 12
Capacity: 8 Amp Hour
CCA: 115
Height (w/terminal): 4.13"
Length: 5.91"
Width: 2.76"
Weight: 5.95 Lbs (w/acid)
1 - 5 of 5 Posts
