1 - 4 of 4 Posts
Respect My Authority!
Does anyone know what years of R6 calipers will fit the R6 fork modification. In other words will 99-02 calipers fit the 03-04 R6 forks? I looked for it in the other threads but I couldn't determine if calipers other than the 03-04 are the same. The certainly look the same but looks can be deceiving. Thanks in advance. :dblthumb
Livin' on the Edge!
Rossi is THE MAN! Glad to help out. BTW, you can use certain years of R1 calipers like I did as well. The older ones still had blue dots and the newer ones have gold dots. Mine are gold and the main difference is the piston thickness which is much thicker on the gold R1's vs the blue dot R6's.
1 - 4 of 4 Posts
