Yea, Maxima Chain Wax is top notch at not causing fling. There's actually a Ducati guy that had a piece about using Maxima for BOTH cleaning and lubing the chain. I tried it and found it to be quite good, leaving zero fling the next day (I always let the bike sit overnight after a good lube/cleaning). Basically, I focused on just the lower part of the chain, between the front and rear sprocket where I could easily access it. Holding a rag behind the chain to keep spray off the tire, I LIBERALLY sprayed the section of chain all over and then proceeded to scrub it down really good with either a brush or rag (in most cases, you could see dirt and grease get pushed off by the Maxima). Once I was done with that bit, I move the chain to the next section and repeat...until the whole chain is done and "dry". I let it sit for 15-20 minutes and then come back and spritz the entire chain with a light coating of Maxima, dabbing off any excess. I let it sit overnight. The next day, the chain is clean and has a slight golden glow to it from the Maxima that's coating the external faces of the chain. A spirited ride, for me at least, revealed no fling whatsoever.
I used PJ-1 before I tried the Maxima and usually had to clean up the wheel after the first ride due to the fling.
