Carbon Fiber Race type gas tank with a 8 hole type filler opening. Taller tank matches the lines much better than the original. Eliminates the line and pad in the tank
Febur 749/999 Oversize Carbon Fiber Fuel Tank: RACE
Was: $2799.95
Sale: $2295.95 One Only at this price
Carbon Fiber Race type gas tank with an easy to use, oversize 8hole type filler opening. The Corsa tank eliminates the line and pad in the tank. Pre preg Carbon Fiber construction with Kevlar and aluminum reinforcement in all the right places. Slightly larger capacity (approx. 1 more gallon). Approximately 9 pounds lighter than the OEM steel tank.
Polished finish
NOTE: Pre-preg Carbon Fiber parts use less resin because it is "cooked" under pressure which results in a stronger and lighter product than typical wet-lay up Carbon Fiber. Pre-preg is the
preferred method for racing, and aerospace. It is more expensive to build with this method but it results in a
superior product. The pre preg fuel tank is extremely strong and will not split the seams or ding like a steel OEM or aluminum tank.
