Here are the Definition of the Fault Codes listed in the FZ6 Service Manual:
Fault Code: 12
Diagnostic Code: --
Symptom: No normal signals are received from the crankshaft position sensor.
Probable cause of malfunction:
Fault Code: 13
Diagnostic Code: 03
Symptom: Intake air pressure sensor-open or short circuit detected.
Fault Code: 14
Diagnostic Code: 03
Symptom: Faulty intake air pressure sensor pipe system
Fault Code: 15
Diagnostic Code: 01
Symptom: Throttle position sensor-open or short circuit detected.
Fault Code: 16
Diagnostic Code: 01
Symptom: A stuck throttle position sensor is detected.
Fault Code: 19
Diagnostic Code: 20
Symptom: Open circuit in the input line of ECU No4 terminal is detected when the start switch is pressed.
Fault Code: 21
Diagnostic Code: 06
Symptom: Coolant temperature sensor-open or short circuit detected.
Fault Code: 22
Diagnostic Code: 05
Symptom: Intake air temperature sensor-open or short circuit detected.
Fault Code: 30
Diagnostic Code: 08
Symptom: The motorcycle has overturned.
Fault Code: 33
Diagnostic Code: 30
Symptom: Open circuit is detected in the primary lead of the ignition coil (# 1, #4).
Fault Code: 34
Diagnostic Code: 31
Symptom: Open circuit is detected in the primary lead of the ignition coil (# 2, #3).
Fault Code: 41
Diagnostic Code: 08
Symptom: Lean angle cut-off switch-open or short circuit detected.
Fault Code: 42
Diagnostic Code: 07, 21
Symptom: No normal signals are received from the speed sensor; or, an open or
short circuit is detected in the neutral switch.
Fault Code: 43
Diagnostic Code: 09
Symptom: Supply power to the injector and fuel pump is not normal
Fault Code: 44
Diagnostic Code: 60
Symptom: An error is detected while reading or writing on EEPROM.
Fault Code: 46
Diagnostic Code: --
Symptom: Power supply to the FI system is not normal.
Fault code: 50
Diagnostic Code: --
Symptom: Faulty ECU memory. When this malfunction is detected, the code
number might not appear on the meter.
Fault code: Er-1
Diagnostic Code: --
Symptom: No signals are received from the ECU.
Fault code: Er-2
Diagnostic Code: --
Symptom: No signals are received from the ECU within the specified duration.
Fault code: Er-3
Diagnostic Code: --
Symptom: Data from the ECU cannot be received correctly.
Fault code: Er-4
Diagnostic Code: --
Symptom: Non-registered data has been received from the meter.
Fault Code: 12
Diagnostic Code: --
Open or short circuit in wiring harness.
Defective crankshaft position sensor.
Malfunction in pickup rotor.
Malfunction in ECU.
Improperly installed sensor.
Malfunction in ECU.
Fault Code: 13
Diagnostic Code: 03
Open or short circuit in wiring sub lead.
Defective intake air pressure sensor.
Malfunction in ECU.
Malfunction in ECU.
Fault Code: 14
Diagnostic Code: 03
detected hose
clogged hose
Intake air pressure sensor hose is detached, clogged,
kinked, or pinched.
Malfunction in ECU.
clogged hose
kinked, or pinched.
Malfunction in ECU.
Fault Code: 15
Diagnostic Code: 01
Defective throttle position sensor.
Malfunction in ECU.
Improperly installed throttle position sensor.
Malfunction in ECU.
Fault Code: 16
Diagnostic Code: 01
Stuck throttle position sensor.
Malfunction in ECU. 01
Fault Code: 19
Diagnostic Code: 20
Open circuit in wiring harness (ECU coupler).
Malfunction in ECU.
Malfunction in ECU.
Fault Code: 21
Diagnostic Code: 06
Defective coolant temperature sensor.
Malfunction in ECU.
Malfunction in ECU.
Fault Code: 22
Diagnostic Code: 05
Defective intake temperature sensor.
Malfunction in ECU.
Malfunction in ECU.
Fault Code: 30
Diagnostic Code: 08
Overturned.
Malfunction in ECU.
Overturned.
Malfunction in ECU.
Fault Code: 33
Diagnostic Code: 30
Open circuit in wiring harness.
Malfunction in ignition coil.
Malfunction in ECU.
Malfunction in a component of ignition cut-off circuit system.
Malfunction in ECU.
Fault Code: 34
Diagnostic Code: 31
Malfunction in ECU.
Malfunction in ECU.
Fault Code: 41
Diagnostic Code: 08
Defective lean angle cut-off switch.
Malfunction in ECU.
Malfunction in ECU.
Fault Code: 42
Defective speed sensor.
Malfunction in vehicle speed sensor detected unit.
Defective neutral switch.
Malfunction in the engine side of the neutral switch.
Malfunction in ECU.
Malfunction in ECU.
Fault Code: 43
Diagnostic Code: 09
Open circuit in wiring harness. (red/blue line or blue/yellow line)
Malfunction in ECU.
Malfunction in ECU.
Fault Code: 44
Diagnostic Code: 60
Malfunction in ECU. (The CO adjustment value is not properly written on or read from the internal memory).
Fault Code: 46
Diagnostic Code: --
Malfunction in "CHARGING SYSTEM".
Fault code: 50
Diagnostic Code: --
Malfunction in ECU. (The program and data are not
properly written on or read from the internal memory.)
Fault code: Er-1
Diagnostic Code: --
Malfunction in meter.
Malfunction in ECU.
Malfunction in ECU.
Fault code: Er-2
Diagnostic Code: --
Improper connection in wiring sub lead.
Malfunction in ECU.
Malfunction in ECU.
Fault code: Er-3
Diagnostic Code: --
Malfunction in ECU.
Malfunction in ECU.
Fault code: Er-4
Diagnostic Code: --
Malfunction in ECU.
Malfunction in ECU.
