EVR has assembled this kit to create a "drop-in" slipper clutch conversion using your original 12T aluminum basket and friction plates.
If your friction plates and basket are in good condition, this is an easy and inexpensive way to upgrade to a high quality slipper.
EVR Ducati CTS Slipper Clutch Hub & Pressure Plate Only
$1190.00 FREE Shipping
EVR Ducati CTS (control torque system) slipper clutch eliminates rear wheel chatter on corner entry improving stability and ultimately lap times on the track as well as safety on the street. The pressure plate features EVR's vent technology that helps keep the clutch cooler (10%), which increases its lifespan. This slipper clutch require no maintenance and has no parts that wear out regularly such as spider springs!
• M20 and M25 mounting kits, which cover all dry clutch Ducati models.
• Pre-installed SKF pressure plate throwout bearing to help make instillation easier.
• EVR anodized aluminum spring caps in your choice of black, gold, red or silver.
• Pre-assembled Slipper clutch hub.
• Pressure plate with bearing cap in your choice of color.
• Easy to follow installation instructions.
EVR slipper clutches use a patented technology that greatly improves operation and clutch life when compared to other slipper clutches on the market. This slipper clutch typically lasts four times as long as the competition and there is no periodic maintenance required! There are also no spider springs or other wear items that need to be replaced regularly like the majority of other slipper clutches require.
Discussion Starter · #2 · (Edited)
EVR Ducati 48T Clutch Basket & Plate Conversion Kits
When your OEM 12T friction plates and basket wear out, you can upgrade to a 48 tooth set up with either organic or sintered plates.
Long lasting and quiet EVR Ducati 48T sintered clutch plate set with hard anodized clutch basket.
You can use this kit with your OEM Ducati dry clutch hub or with the EVR slipper conversion kit allowing you to switch to a 48T setup which will greatly increase your clutch life, reduce clutch noise and improve your clutch function. This is a fantastic upgrade that saves money in the long run.
Sintered plate sets are suggested for aggressive street use and all forms of track riding.
EVR Ducati 48T Sintered Plates & Clutch Basket Set: 1098 / Hypermotard 1100
$515.00 -- FREE Shipping
Fits Ducati Hypermotard 1100 and 1100S (2008-09) and 1098, 1098S and 1098S Tricolore models.
EVR Ducati 48T Sintered Plates & Clutch Basket Set: 1198 / Streetfighter / M1100 / HM 1000 EVO
Fits Ducati Hypermotard EVO and EVO SP, Monster 1100/1100S/1100 ABS/1100S ABS, Streetfighter, Streetfighter S, 1198 and 1198S Corse models.
EVR Ducati 48T Sintered Plates & Clutch Basket Set: 748-998 / 749-999 / MH900e / M900-1000 / S2R / S4R / MTS1000 / SC / ST / SS
$490.00 -- FREE Shipping
FitsDucati 748, 748S, 748SP, 749 Dark, 749, 749S, 851, 888, 916, 996, 998, 999, MH900e, Monster 900/900S, Monster 1000/1000S, MS2R 1000, MS4, MS4R, MS4RS, Multistrada 1000/1000S, SportClassics, ST2, ST3, ST4 and Supersport (all models from 1997-02) models.
EVR Ducati 48T Sintered Plates & Clutch Basket Set: 916S/SPS / 996S/R/SPS / 998S/R / 999S/R
Fits Ducati 888SP, 888SPS, 888SP5, 916SP, 916SPS, 996S, 996SPS, 996R, 998S, 998R, 999S, 999R models.
EVR Ducati 48T organic clutch plate set with hard anodized clutch basket. You can use this kit with your OEM Ducati dry clutch hub or with the EVR slipper conversion kit allowing you to switch to a 48T setup which will greatly increase your clutch life, reduce clutch noise and improve your clutch function. This is a fantastic upgrade that saves money in the long run.
Organic plate sets are suggested for street use.
EVR Ducati 48T Organic Plates & Clutch Basket Set: 1098 / Hypermotard 1100
$430.00 -- FREE Shipping
EVR Ducati 48T Organic Plates & Clutch Basket Set: 1198 / Streetfighter / M1100 / HM 1000 EVO
EVR Ducati 48T Organic Plates & Clutch Basket Set: 748-998 / 749-999 / MH900e / M900-1000 / S2R / S4R / MTS1000 / SC / ST / SS
$410.00 -- FREE Shipping
Fits Ducati 748, 748S, 748SP, 749 Dark, 749, 749S, 851, 888, 916, 996, 998, 999, MH900e, Monster 900/900S, Monster 1000/1000S, MS2R 1000, MS4, MS4R, MS4RS, Multistrada 1000/1000S, SportClassic, ST2, ST3, ST4 and Supersport (all models from 1997-02) models.
EVR Ducati 48T Organic Plates & Clutch Basket Set: 916S/SPS / 996S/R/SPS / 998S/R / 999S/R
